Yes correct. We didn’t realise it had different hole sizes at each end until removed!I did my carb revision and I didn't take attention.
I think you are talking about this:
I don't know the correct direction, but tomorrow I confirm how mine is installedYes correct. We didn’t realise it had different hole sizes at each end until removed!
so… which end goes where?
Ok thanksI don't know the correct direction, but tomorrow I confirm how mine is installed
Great thanks. Still having problems with car. It will not pump fuel. Have replaced fuel pump, checked and cleaned carb, tank is clean, all pipes are clean. Take pipe off carb and fuel pumps correctly. Put it back on carb and no fuel pumped throughI have the small hole direction down and the big direction to the T
yes, zenith 28 carbDid you put everything like before on the carb? What carb have you?
Try what @mojobaby says..and if you changed the needle valve, put the old again. I'm from portugal too, if you need something tell meyes, zenith 28 carb
Thanks yes will try that, but at the moment cannot get fuel to the carb from the pump. Where do you buy your spares in Portugal?Try what @mojobaby says..and if you changed the needle valve, put the old again. I'm from portugal too, if you need something tell me
But you only can't get fuel when the pipe is connect to the carb, right? So this can be what mojobaby said.Thanks yes will try that, but at the moment cannot get fuel to the carb from the pump. Where do you buy your spares in Portugal?
Ok thanks.But you only can't get fuel when the pipe is connect to the carb, right? So this can be what mojobaby said.
I don't have a place, I search in several, because it's not easy, normally I get end of old stocks.
Where do you buy it?I used this product.. You can find other products for motorcycle carbs, and the result is the same
