1108cc engine needed.
MOO229R
Hi, i am struggling to get a good 845cc engine for my 72 R6 , however I have been offered a rotten R4 van with a seized 1108 . I would have all the items to change her to the 1108 if I get a good engine. Can anyone help? Also would a 1289 or 1397 one fit?
Thanks.
1108cc conversion.
I might have an 1108 engine, Ill have a look.
I anm sure you know you need to fit the 1108cc with the later gearbox, as the engines spin in opposite directions.
Also you will have to fit a later radiator as it sits further forward in the later car.
You would also have to provide clearance for the bonnet because of the radiator position and the difference between the bonnet strengtheners in the later 1108cc and earlier cars.
In other words you need to shove the whole lot in, then it is easy.
Once you have the later running gear, the larger engines from the Mk1 5 Series are interchangeable on a Renault 4.
I would fit front discs from the later car as well.
