Interior is now complete. That was a big job to do the headlining around the sunroof and the carpeting. In all a day and a half of constant effort.
I decided to cover the sunroof surrounds (came with Twingo Sunroof) with the same fabric as I did the headlining (solid type). I think it looks better although it was a chaff trying to get it all clicked in and held in as there was a couple of mm of extra material.
Carpet went in OK including a good helping of underlay, hoping it will be a little quieter now.
As you can see the headliner needed covering - I just wish I had cut the opening bigger around the bolts, it made the job harder when fitting it back on.
I used a sticky back felt, quite expensive at €27 per metre but it was easy to work with and matched the carpet really well.
I also covered the surround strips in the same felt.
Put in thick underlay in the front and rear and some thinner in the boot.
Rear was easy - picked up a tip to make the holes. I used an old soldering iron and that just melts the perfect hole and stops the carpet strands spinning into the drill or screws.
Finished the front - not too bad.
Roof matches - we seem to be very grey but goes well with the black interior and grey paintwork.
Shelves look neater and I have put carpet up on the bulkhead, again for some noise dampening.
