2004 Renault Megane II 1.4lt Auto - Injection Fault on Cold Starts
kdezilva
I own a 2004 Renault Megane II, 1.6lt Auto, with just over 60,000kms on the clock.
Just the other night, I started up the car after work and a warning light came up on the dash as i took off 'Injection Fault' 'Service'. I pulled off the road to check the manual, and afterward, tried to start up and there was no problem, and I drove home. This has happened once more. If I let the engine warm-up a little before taking off there is no issue.
Is this something that you have come across before?
She did get the 60k service recently, but, do you think that I may need an fuel infection service?
What would you recommend. I know that if I drive it in to a mechanic, the problem will not be apparent as the engine will be warm!
I hope you can offer me some advice.
Hi,
if the warning light has come on then the computer has stored the fault so the easiest way is to take to a dealer for them to read the fault. Saves a lot of hassle trying bits and pieces
cheers
andrew
