Changing window channels
must remove widows with frames from doors, then take apart glass of the frame and you can remove rubber inside window frame.
Oh... I think I have this project one day on the passenger window .. Sounds bigger than I expected
actualy is not that hard.
usualy plastic frames has metal clips on inside side under rubber and metal frames has screws inside chanel.
But it is not stric rule.
One of this two metods is used to secure frame to the door.
Remove clips or screws, inside part of rubber flip over door frame and just gently but strong push whole window out.
Be careful not to drop window to the ground while pushing it out.
It will go much easier if you start pushing at one corrner.
That is it.
Sounds like it's going to be a right side if anything else is to go by
