iMacThere4iAm
Tom Long
- Morecambe
I've recently noticed an odd metal clanking or clattering sound that I can't trace the source of - it happens mostly if I let up the clutch jerkily, and sounds as if some large metal part is not quite bolted on right :eek: or as if there's a linkage in the transmission with a lot of play
I can't see or feel anything loose but I'm terrified my gearbox is going to drop onto the road or something!
Any ideas where I should be looking?
I don't know if it's relevant, but I just removed the extra protective plate bolted under the engine by the previous owners - It was attached to the front of the cross-member and went back as far as the floor pan with bolts onto the chassis.
