Hi
I'm planning on changing the disks and pads on my 86 GTL, Girling brakes.
To remove the hubs to get at the disc, I presume it would be sensible to buy a 3-legged puller? If so, what size (the cheap sets seem to come in 75, 100 and 150mm sizes)
Presumably I put pressure on the drive shaft end until the hub gives, then pull hub and disc off.
Haynes is his usual skimpy self here and the picture guide on this site makes it look all too easy - I expect problems!
