Electronic ignition?
Baron5
Kent
Has anyone swapped the points for electronic ignition on there 4 or 5?. I've been looking at a few different set ups and was wondering if anyone could recommend any?. Also does anyone know what I ignition I have on mine? Duccellier or bosh ect? 1.1 1984 MK1 R5 LE CAR
Also looking for engine and gearbox mounts if anyone knows a source?
You can have any brand of ignition in your r5 le car.
The only way to find out is to look under the bonnet.
Usually the brand and type are visible on the dizzy.
As far as electronic ignitions, I'm using the 123 ignition. It will fit to the r5 with no trouble at all.
Engine and gearbox mounts you can find at der fransoze. https://www.franzose.de/en/Home/
Regards, Robert
