The pre-73 (ish) cars had a single piece steering column (no upper joint). Changing to a later column would be a pain as the steering wheel fitting is different. But you might get away with the original parts.
A point to ponder! Is the upper steering joint a safety/crash inclusion in the design? If so, I would rather have it! Would the newer column allow the fitment of a more recent padded steering wheel from a later Renault? Is the steering wheel fitment related to the dashboard layout or is it a change from 3 bolts to splines?
In terms of clearance for the steering, perhaps the fitting of GTL inner guards might be an option. Do they fit without problem? Would the bulkhead have to be changed? If so, could this be a welded cut and shut of the RHS section (oil filter etc) or would the entire bulkhead panel need replacement?
What's your plan for the handbrake? The GTL handbrake needs space between the two front seats, so wouldn't be an option.
I guess that the handbrake will have to come from a GTL and I will have to change the torsion bars and rear trailing arms. The rear suspension bits will have to come from a GTL van, because of the rear handbrake and the roll bar. Perhaps Renault changed the relative spring rates on the later cars too as the car got heavier/more powerful?
I have recently looked at a Rennospeed chassis repair on the web and I think welding the original handbrake mount between (behind) the seats would be a relatively easy thing to do. The set-up seems basic in the extreme. Please correct any errant thoughts here!
I don't think that I still have the original seats, but I think that they were on individual runners. Certainly, there was no gap for a handbrake. GTL seats as well, then - mabe runners as well. Would Renault 5 front seats fit? I don't have to worry about the rear seat.
I'm in the middle of fitting a 1400 Gordini engine to a '68 Renault 4. Having the carb on the wrong side on my engine causes a whole load of extra trouble (mostly with the steering).
I'm not jealous! No, I'm not ..........really!
More pics would be great. It'd be great to see the work in progress. Unless I have misread what you are doing, you will hit some of the problems that I will.
I think, Clementine, that we might be in a parallel universe, geographically separated. Whilst I'd like to keep the car as original looking as possible, I just want to have a reliable and capable car for these modern times!
I shall follow your triumphs (and tribulations) with great interest.
Keep up the good work!
Regards,
David
