Apologies for being so sloooow to get back to you_this does very much look like the exhaust system under my car, and the number on the oval plate is 1123, the number 3 could correspond to the third letter 'c' in the alphabet as the car was fabricated in Poland. It'd be a huge help if you tell me their significance. I now need all 4 parts of the exhaust (I had it sleeved last November). Thank you for your patience, kind wishes, JuliaHi
Is your R4 a late TL (112C on the oval plate under the bonnet)?
Does your system look like this?
Hi JuliaApologies for being so sloooow to get back to you_this does very much look like the exhaust system under my car, and the number on the oval plate is 1123, the number 3 could correspond to the third letter 'c' in the alphabet as the car was fabricated in Poland. It'd be a huge help if you tell me their significance. I now need all 4 parts of the exhaust (I had it sleeved last November). Thank you for your patience, kind wishes, Julia
Hi Julia
The fact that it's an R1123 makes it difficult to be sure which system the car has. It'd be helpful to know what type of engine you have - there's a plate on the right-hand side of the engine, just above the oil filter. Some underbonnet photos would be great too!
You mention a clip between the manifold and the first pipe - this made me think your car might have an 845cc engine. Does the clip look like this?
Exhaust clip (58mm) for the elbow pipe. Suitable for Renault R4, 4CV, Dauphine
Exhaust clip (58mm) for the elbow pipe. Suitable for Renault R4, 4CV, Dauphine No. 82134www.franzose.de
Ah, glad thanks for your time and help, AndyThanks for the photos.
Which bits of the system do you need?
To complicate things, there are two different systems - although both have the same first pipe (the one that connects to the manifold - 5 in the diagram below) and silencer.
The part numbers are:
5: 7700578443
6: 7700657468
7: 7701365697
8: 7700859523
This is the system that the parts book gives for cars with engines like yours up to 1985ish; the later system has different numbers for pipes 6 and 7:
6: 7700757174
7: 7700757178
I can't be sure which system your car has.
The long pipes are getting hard to find in the UK. The easiest - but most expensive - way would be to order a complete system from, say, Der Franzose, but you might find the pipes on eBay. You just have to make sure that pipes 6&7 are the right ones, and that, ideally, they're made by the same manufacturer.
I can help with pipe 5, if it helps:
The clamp you mention is easy to find a replacement for - most people use U-clamps, which are widely available (try eBay).Manifold to 'S' pipe/silencer pipe for sale
Genuine Renault NOS: 7700578443 The first pipe in the system - between the manifold and the S pipe (or underwing silencer). For Cleon engines. £10 plus postagewww.renault4.co.uk
11 and 12 on the diagram just refer to pipe diameter: 11= 45; 12 = 36.Ah, glad thanks for your time and help, Andy
Yes, I would like the first part of the pipe you are selling. I am jn Stroud, so, if if you're willing I could drive over to Cheltenham and collect it when I return home from working, 8 th June, and you could see the engine, in person?
The images of the pipe you've supplied look very like those on my car.
I've been looking online and there are different manufacturers, Bosal , Faurecia, Walker doesn't seem to be rated, Dacia, can you recommend?
It seems parts 6and 7 can have the curved end on the long pipe or the wiggly one, but not both or either
What is part 12 called?
Thanks again, Blauslia
Most appreciated, Andy, it's already much clearer after pouring over pages and pages of diagrams and data without really knowing what is needed11 and 12 on the diagram just refer to pipe diameter: 11= 45; 12 = 36.
Bosal pipes and silencers are really good quality (the Bosal number for the rear silencer is 200-925).
I'll drop you a pm with my mobile - I should be home on the 8th.
