I also feel Reinz is a ok brand but get a bit confused though the shims is plastic."Paper" seals were made from a material Renault called Excelnyl. As long as these seals are some 0,1mm thick (not 1mm as is the case with earlier copper seals) I would use them. Reinz is a trustworthy company after all.
Did you try here
Willkommen im Online Shop von Der Franzose Automobiltechnik
Europas größter Ersatzteilhändler für französische Oldtimer der Marken Citroën, Peugeot, Renault, Panhard, Simca, Talbot. Über 33 Jahre am Markt, weltweiter Versandwww.franzose.de
Or here
Parts and accessories for old cars | Melun Retro Passion
Specialist in the sale of car parts and accessories for vintage cars from 1900 to 1980. Specialist Renault 4L R4. Online order. Secure payment.www.melun-retro-passion.com
Or here
Renault 4 onderdelen
Onderdelen voor uw Renault 4 , alle modellen van 1961 tm 1993.www.renault4onderdelen.nl
At this Netherlands web shop i managed to find sprockets for 688-712 engine. And guy there was very helpfull finding right part .
I have also bought plastic paper gaket for cilinder liners. Had same question about them but guy that works a lot on r4 engines said he use them also and they are alright. I chouse to belive him and will use them when engine rebuild is on schedule.
The Netherland shop seem to have everything I need, Melun and Fransose are out of stock or only have parts of timing gear set.
https://www.renault4onderdelen.nl/ is new for me, but they seem to have what I want.
Thanks fore sharing your experiences and remind me about put on flywheel first (had put sump first otherwise) thanks.After lots of swearing and fails trying to persuade both cork strips to stay in place, and adding the fact that both of them are almost invisible with engine on car (so that I couldn't see if they were in place when the sump was back on), I threw them away. Instead of them I used a thick - around 5mm - and uniform bead of good RTV sealant (Permatex Supra Black or Grey is excellent), keeping the side cork gaskets. Worked a treat on 3 or 4 cars I have used this technique.
For side gaskets I use a sealant like Hylomar or Indian Head.
Be aware that you should first fit flywheel, then sump!
Gaskets and sealants are a bit complicated or very easy dempending on approach.It seems that modern gasket sets have mismatched parts...either too wide like yours, or too thick, which was the case on some sets I got. Problem was that front and rear sections would not allow the sides of the sump to touch the side gaskets wihtout having to deform the sump by overtightening...that's how I decided to use RTV.
Remember that Renault themselves ditched the four piece gasket originally fitted to Cleon engines in favour of RTV sealant, and factory sealing methods of the '60s ('40s actually when it comes to the Billancourt engine...) were not that efficient.
