billythefish
As every one knows (excluding myself) the gearbox on my 1971 R4 has two drainage oil plugs underneath one on the front, which I was unaware of and one in the middle.
Can any one tell me if inside the gearbox is as one, with the oil or is it in fact in two separate sections, because I can't get the front drainage plug undone even after spraying it with WD40 or heating it, the plug will just not move and I have even broke an open ended spanner trying to undo it.
I do not want to force it to the extent that I do irreversible damage and then be unable to find a replacement drainage plug.
The idea I had in mind was to some how lift the car up at the front to enable the oil in the front compartment to seep through but I don't know if this is possible.
billy
billy
