GTL wheels
Those wheels are for a Renault 16 or a Renault 12.
They will not fit a Renault 4.
There are smaller wheels of the same design available that fit the r4
Are you sure?
The vendor said they were from a r5 laureate, and assures they will fit on a r4...
What is the detail from which you recognize the two differend kind of wheels?
If as the seller says, they are from a R5 Laureate then they will fit perfectly. The style of wheel was used on the R12 only slightly larger - that wouldn't fit. Looking at these, they look exactly the same as the ones on my van so should be fine to fit on your R4.
they are my favorite type of wheel but i have never had a car with them fitted
My favourite ones are the earlier type, those with chromed plate in the center, but my r4 has front disc brakes so I can not fit them.
Those are the number two...
I'd like certain type of alloy too, but iron wheels are less "fragile", need less attention...
Just sanding, painting again (I was thinking to made them all white, as the car, and depressed areas black) and fitting.
