Vedran, it makes little difference whether you measure these heights against the ground or somewhere else, provided you have a fixed reference. The point is to position wheel centre 80mm higher than underside of chassis rail.
Petak, all rubber bushes on a Renault 4 are of the Flexibloc type, which means that rubber is bonded (vulcanized) to both inner and outer bush sleeves. Therefore, rubber is stressed in torsion when suspension moves up and down, rather than the sleeves sliding on the rubber bush, as would be the case in other cars.
By positioning the wishbones and rear suspension arms at a random position then tightening down their pins, you will end up with bushes that are constantly stressed, or working beyond their useful working angles, so they will wear out quickly (vulcanizing between the rubber and the sleeves breaks).
The factory setting is at about midpoint of suspension travel, so bushes are almost non-stressed with car unladen, and stressed towards both directions, when suspension is compressing and extending.
Think that we have some 20 cm of suspension travel at each wheel to realize that these bushes are working rather hard!
