AdamWilkes
- Poole
I'm starting to get fed up with my clutch - the lever at the gearbox is free-moving, with some free-play and while the rest of the action is heavy (by hand!), it seems smooth.
The problem is that when I press the clutch pedal, the action there is rough, stiff and noisily grating - like heavy metal scraping. The clutch cable is new (but possibly rubbish quality - or dried-out lubrication?), replaced as the old one was getting stiffer and turned out to be close to wearing through the strands near the pedal end bend (inside the sheathing). When I fitted the new cable, it took a few commutes to settle the cable down - it stretched quite a bit initially (clutchless gearchanges were practised on the last day before re-adjustment).
The pedal action is often worryingly heavy, obstructive and horrible acoustically. The cable linkage at the pedal looks correct, and is all loose and greasy. I have removed the new cable and tried to coerce oil down the sheathing, but all is so snug down there I don't know if any reached far at all, and little change in cable/clutch 'quality'.
The clutch (complete kit) is a year old, and all seemed fine to start with (and probably still is).
Should I try another cable? Maybe there is magic in the cable which I need to summon ? Feels like it sometimes!
I am resorting to using my camper-van for work now, as the lack of clutch action quality has worn me down!
