R Rob Gosev Enthusiast Messages 21 Location England Aug 29, 2023 #1 Hi guys. Doing a big drive from Croatia to Germany Done good for 4 hours or so but now Overheating Symbol comes on and disappears Any tips? No bad smells , coolant is fine .
jjad Enthusiast Messages 1,565 Location Herefordshire Aug 29, 2023 #2 Keep the heating on in the cabin, if you can bear it! It could be the timing is out. Or the cable for the overheating lamp is shorting somewhere.
R Rob Gosev Enthusiast Messages 21 Location England Aug 29, 2023 #3 jjad said: Keep the heating on in the cabin, if you can bear it! It could be the timing is out. Or the cable for the overheating lamp is shorting somewhere. Click to expand... What’s the switch for the heating or am I missing it
jjad Enthusiast Messages 1,565 Location Herefordshire Aug 29, 2023 #4 Sorry, I meant rotate anticlockwise the knob inside the car for turning on the heating of the cabin. It's the bottom-right knob in this photo on this website: https://www.renault4.co.uk/forum/attachments/818e6778-1dff-4023-a127-5ed147bb4f0a-jpeg.25323/ That will cause the inside of the car to get hotter of course, but might help your engine to cool down a little bit.
J jcarruthers2 Enthusiast Messages 491 Aug 30, 2023 #5 Hi Possible areas to investigate: Radiator fan not cutting in at correct intervals (investigate radiator switch) Check thermostat
