Steve Hennessey
Moderator
1 x pair of inner rear hub bearings (7703090267) and grease seals (7703087071) for the GTL and Mk1 R5
£16 plus postage (£2-50 second class)
It's rare for both inner and outer rear wheel bearings to go at once. If your inner ones go then these will be fine and you have the seals as well. If your outer ones go just pop along to your bearing shop. Cheaper than buying kits. If a seal is shot and covers your rear brakes shoes with grease then to replace it you are likely to destroy the bearing in removing it.
