Andy Sherlock
Hi all,
Our car has always had a bit of a dribble from the radiator, for some 10 years I haven't located it, until now.
The thermal switch for the electric fan (located at the base of the radiator) packed up so I got down to changing it. When I unscrewed it from the Radiator it was loose, I didn't think anything of it as I was fitting a new one, which I would tighten up.
The new switch complete with seal washer was replaced and screwed in, but it would not tighten up.
It turns out the plastic housing on the radiator is split local to the plastic threaded housing, and this has been exaggerated by my messing with the things. As such, the radiator is now leaking badly from this area.
My reason for posting this on the forum is that I am hoping that some of you may be able to help with some useful hints and tips regarding removal and replacement and/or refurbishing what I have here. I haven’t had any radiator problems with the car before so this will be a new job for me. So if anyone can offer any help to make the job go smoothly for me, then it would be much appreciated.
One question I have is, would it be helpful to remove the bonnet, and if so how do I do this without damaging anything?
Finally, no it wasn’t me that over-tightened the switch in the first place, this is the first time I have messed with this part of the car.
Thanks all for your help in anticipation.
