Martins Method in action
I thought some may like to see Matins method in action, it works well.Slaken the tappet,slide across the rocker and remove the push rod, then rotate the rocker as shown,result plenty of access to the two bolts in question.
I do have a related problem of my own though which I wanted to get some advise on. On removal of the cylinder head I was surprised to see coolant filling the various spaces between the bores, On closer examination there was coolant in the area where the push rods sit on the followers, also coolant on two bolt holes! little coolant in cylinder No 1?? . I did have a little hitch when I lifted the head, I'd forgotten to take off the lower heater hose and lifted the head 10mm or so with it attached before realizing. Undid the hose and then lifted the head with all but two push rods still attached to the head.
I have syringed out all coolant and lowered the level in the main channels, but I'm a bit concerned....this engine has not run for 15 years. Help appreciated! When I drain the coolant I did not take out any plug from the engine block, was this my mistake?
One further question I read about being careful not to lift the push rod followers but one seems a little higher than the rest? Do they go up and down over the cam and if so could this be the reason this one is higher and also what happens if you do lift them, why are they difficult to get back.
Knowing the experience out there I'm sure someone will have an idea
