I've spent the day recommisioning my '85 GTL which has been laid up a couple of years
One of the niggles when it was last driven was intermittant starting. Other than that, the car was running perfectly; I've stripped the starter motor and solonoid, cleaned it all up and reassembled and it seems fine.
But now I can't seem to any gears when the engines running. I've had the clutch cable bracket off to get the starter motor out so I first thought the clutch adjustment had gone out but adjusting the tension on the cable doen't make any difference. Is the clutch adjustment sensitive or is more likely the clutch has seized since it was last driven?
Cheers, Mark
Cheers, Mark
