A quick question please - I have just taken delivery of the new outer suspension mounts for barnfind's project. I note that the (original) metalastic bushes inners are seam welded to the swing arm pivot tube. Obviously I can grind it all away, press the bushes out of the new mounts and seam weld them in place (slowly and not allowing too much heat to build up) then press the outer mounts back on....
But is there a better/quicker way?
I did consider putting 4-5 decent spots on the inner face where the tube ends up but not doing so till the car is back on its feet with a bit of load in the back to give the bushes half a chance to settle in the right position before locking them.
Any thoughts??
Any thoughts??
