bantamallan
The R/H rear wheel on my 85 GTL has negative camber and scrubs a tyre in a couple of thousand miles. The local Renault garage says a bent stub axle and the normal fix is to bolt on an old wheel and beat the s**t ot of it until straight. I have a new axle from Liam but before I start work could it be rear chassis out of alignment. There has been some welding to the chassis which looks OK. I plan to lift the body to check the condition of the chassis , I'm just doing a Beetle for my daughter, can it be any worse??
thanks
bantamallan
thanks
bantamallan
