- Bedford UK
Mr Reno sent a few carbs over including a couple of zeniths. One of the zeniths has cleaned up really well. I've had it apart and blown out all the jets and cleaned all the filters.
What a transformation after running around with that solex 32DIS for a fortnight. Runs really nicely, idles smoothly, and power is up a touch on the Solex especially mid range.
There is one snag though - jab the throttle sharply at low revs and the engine dies a bit before accelerating. Happens reving the engine at idle too. I'm wondering if it might be the accelerator pump which needed a bit of effort to get working and still feels doubtful. I've checked the vacuum advance, that the restrictor is in the vacuum pipe from the manifold, and that there aren't any obvious vacuum leaks. Oh, and I've blocked the vacuum thing that opens the choke (if it's shut) under high vacuum.
Anyone had this symptom before? And anyone know of any botches to get a good seal in the accelerator pump on these things?
