edwardhall
MORNING
IS IT POSSIBLE TO FIT A SOLEX CARB ONTO A 4 GTL 1984 THAT HAS A ZENITH CARB.
THANKS:smile:
THANKS:smile:
Hi Edwardhall,do you mean the rocker box breather? If so, I tied it off to the bulkhead with a cable tie, there was a convenient small hole for this, and cut so it so it just touched where the body is bolted to the chassis. If your engine like mine is in good condition,just a small amount of vapour/oil will dribble on to the chassis. Another modification I've done is fit electronic ignition,if you would like some details please let me know as this is a very worthwhile mod to do. Hope this helps,regards Cornish4.Thanks for your reply, ould you explain in a bit more detail abbout what to with the pipe
thanks
HELLO
THANKS FOR THE ADVICE ON THE CARB,I DID WHAT YOU ADVISED AND THE CAR IS RUNING REALLY WELL I AM WAITING FOR THE GUNSON COLOUR TUNE TO SET MIXTURE SCREW.
:smile:
