orsome
1
- FIN
won't start 2
- Brake ligths do'nt work-i do have that hydraulic switch with two cables,
- register back ligth not working.
I just wonder should i have two red ligths on the instrument panel when inginition is turned on -or just one?
Today i have non red ligths- can it really be so good oil pressuire with new parts that it holds pressure enough owernigth?
I doubt the alternator ?
Earthing-should i have a wowen widw cable going from gearbox to RHS FRAME BEAM?- SEEN SOME OF r4'S HAVING SUCH
I'll have tomorrow net points+capasitator(condensator?) plus new candles.
changed the remaining 23years old gasoline
to few liters fresh one.
- gas pump is working and giving feed to filter-OK
tested ignition with two old spark plugs-no spark
-tested spark with one new spark plug-no spark identified
whe:eek:re to searh ?[/QUOTE]
