can any one tell me where the fuel gauge is in the tank as in the car it is not giving me the correct reading
I took mine off when I had the tank cleaned and it was easy enough with a little patience.
**okIt depends which way you have installed the float in the tank.
**it was one new package, there was only one way todoit.Old float was full of petrols(leak)
I assume the arm of the float has to lie at the bottom of the tank and rise as the petrol tank is filled.
**yupp
I would also assume that you require the correct fuel gauge with the 25 litre tank.
**yupp, i did check it from supplier at purchase
All assumptions I'm afraid.
