jcarruthers2
Further to my last thread, I was wondering whether anyone knows whether the aluminium/plastic type radiator which is fitted to my R4 is interchangeable with the all metal radiators which if I remember rightly were fitted to the early R4GTLs. The reason for asking is that I decided to change my radiator as it is quite beat up but everything was functioning as per normal. I ordered a radiator from Renault and received an all metal exchange unit which I fitted to the car with new thermostat and rad switch from Renault and the fan does not cut in at all, even though, I thoroughly bled the system. I tried 3 rad switchs (1 new and 2 used but known to be working) and two thermostats (1 new and 1 used, tested in advance and working) with the new radiator, but no joy. When I put the old radiator back with the old rad switch and thermostat, bleed the system, the fan cuts in. The all metal radiator does look a tad wider than the aluminium radiator. Any advice would be greatly appreciated.
Best Regards
Best Regards
