Steering column bush/bearing
Piet
Hi all,
what is the best lubricant to use on the steering column top bush/bearing? I assume there is a roller bearing plus a rubber bush, do you need to use anything special to not damage the rubber?
Cheers
Piet
Hi Piet, no bearings in there, just a bush. My steering made a squeaking noise when I turned the steering wheel. I used a silicon spray and it loosened up the steering and the squeak disappeared.
Silicon is quite safe for use on rubber:)
Think there is a phosphor bronze insert to the rubber Bush
This part is nla but there is a roller bearing replacement available originally listed for older renault models 21 25 etc with pas
Paul do you know if that bush would fit the R16 and where one could get one.Gary
