mojobaby
While cleaning my manifold today, I decided to clean out the little pipe that connects to the top of the rocker cover(oil breather pipe).
It was absolutely blocked as was the rubber pipe leading to it
When the pipe was cleared I found the reason for the blockage. The hole into the manifold had been closed from the other side (inside the manifold), with welding.
I knocked a small hole through with a hammer and nail and managed to get a 1mm wire through.
I looked at old photos of the carb and noticed that the pipe from the rocker cover is split in 2. one goes to the manifold and the other goes to the top of the carb.
So my question is, are both pipes necessary? And why was the bottom hole welded close
