Could not locate 4 tyres for 100. You did very well indeed.picked up 155/55 R13 for a 100 fitted brand new for my 5j bandeds I believe.
Paul165 65 13 are easy and cheap er as they are not in the performance type class of tyre
Clearance gearing and ride will be fine
Info here
Tire Size Calculator - Compare Tire Sizes | Tacoma World https://www.tacomaworld.com/tirecalc
Event-tyres man visiting on Friday to renew all 4 tyres.I've got 165/65/13 Falkens on my van, no issues with rubbing or clearance. Got four fitted just before Thenay by Event Tyres (http://www.event-tyres.co.uk/)
Looked at comparison of 135/80/13 to 165/65/13 with following results:I am planing to go with 155/70/13 tires for alpine rims....
it is closest to 135/80/13
Thank you for that information.My 165 65 r13's rubbed slightly on the right hand side wing, not sure if you will Have the same problem too...
Suspension height and driving style can cause slight difference in clearances I've got 185 60 13 on peril and had to flatten lip upwards on front edge of floor pan behind wheel
Did try 175 70 13 once on f6 but unless driven very sedately lots of rubbing noises☺
What's the verdict then tom you must of driven by now ?
