Geoff in the Gully
Getting it together
- Upper Ferntree Gully, Victoria, Australia
I've got a bit of an odd idea to put out there.
We know the 845cc engine rotates in the opposite direction to the 1100cc engine and we have to be careful to mate the right 4-speed box otherwise we end up with 4 reverse speeds and one forward.
A while back I looked into improving performance by using some parts including the camshaft from a Dauphine Gordini engine. The Dauphine is a rear-engine version of the 845cc Ventoux engine.
I eventually figured out I couldn't use the cam because the Dauphine Gordini engine rotates in the opposite direction and the cam would be opening the inlet and outlet valves in the wrong order.
But what if we want the engine to go the other way?
Can we use Dauphine bits to reverse the direction of our 845cc engine so we can use a later 354 gearbox?
I might be easier to do that than to find a gearbox that goes the right way.
The question is then just what does it take to reverse the direction, apart from the cam.
Is the crankshaft the same, or is it balanced differently?
Are the distributors rotating the same direction?
I can't think of what else would be different.
What do you think?
What do you think?
I would put in a reverse-turning motor and gearbox as is.Then just mount swivel-mounts for the seats.
