JonathanT
Not normal for Norfolk
- Wymondham Norfolk
Hello my learned friends. I've been given some very good advice by an professional Renault restorer. He suggests putting the engine in after the body is installed onto the chassis. For the following reasons:
1/The body hooks round the back of the engine and it's difficult to get the body aligned correctly for this reason
2/When The mastic is in place on the top edge of the chassis the body has to be aligned very carefully as the slightest contact will make it stick. To this end he suggests using bolts placed in the holes with the heads cut off as an alignment device
Now I'm inclined to ignore advice at 1/.The reason being is that while the body is away at the paint shop I can be completing the chassis and installing the engine and linkages so that everything is completely ready for when the body returns.
So my friends my question is what should I do, or what would you do?
