JonathanT
Not normal for Norfolk
- Wymondham Norfolk
2/ Then finished off the rear axles by fitting the Crown locking washers and split pins greasing up and banging on the caps with a mallet.
3/ fixed the bonnet tie straps
4/ fixed the bonnet support stay. I broke the little nylon saddle clamp but then had the idea of using model aeroplane landing gear saddle straps. A little modification had a very satisfactory result.
5/ the bonnet rubber seal below the windscreen on the bulkhead was poorly fitting. Corrosion had pushed the cut ends apart preventing it sitting tight on the flange. So with a hack saw cleared the rust out of the rubber at each end then using Evo Stick glued up the mating faces allowing it to air dry before pushing together . The rubber now sits tightly at each end without rolling off. Washing pegs help keep all tight while the glue set
As a little motivational reward
) Repaired the insulation in places
