Paul Narramore
pre-moderated
 - Aylesford, Kent
Yesterday I fitted a pair of yellow halogen 60/55w headlight bulbs bought from Retrospec Parts (£14.20 inc. postage). I'll just have to see how good they are when I next take her for a drive at night, although as I'm a stop-at-home, that might not be for a while.
What I did notice whilst I was delving about under the bonnet was the awfully crusty wiring connections at the back of each sidelight/indicator. These proved very easy to remove although there was a lot of green slime at the bottom of each lens. All cleaned up - although I must replace the sealing rubber on one side, and with each terminal nice and shiny after cleaning up with emery cloth and coated with Vaseline, they all went back in place, although one of the internal brass terminals was broken. Neither indicator worked although one side turned out to be just a wonky bulb holder. After chatting to Mr Reno, I carefully drilled out the rivet holding the broken terminal into the bottom of it's socket and then struggled to find a tiny enough screw & nut. M3 would have been fine but I have nothing that small. A tiny self-tapper did the job with the internal brass fitting from an electrical connector block. A bodge, I agree, but it should have work............but didn't. Back this morning to check out that there's current reaching the lamps.
When I bought the R4, it came with a box containing a few spares, amongst them were three drivers side sidelight/indicator fittings, each one having an identically broken indicator terminals. Crappy design if you ask me.
I shall go back this morning to try to get the damned thing to work as there's the Classic Car Event at the Friars on Sunday, which I have booked to go to.
      -Reid.
