Paulhas4renaults
Member
- Essex
Hi forum, I've just purchased a 1.4 Monaco that has been off road since 2014 , on start up the engine gains in rpm to about 3000 rpm and holds there about. I've had a look at the idle jet in between the twin port on the Webber drt 32 carb , and they are all closed shut, when you open the ide jet the rpm drops to wherever you set it too, but smoke apears from the exhaust and when closed the ide jet gains in rpm and smoke clears . Are the idle jet meant to be closed and is the problem else where. I do have a video of the start up of engine , but can't seem to upload it on to post. Thanks if any one can help
