Cornish4
Le Dazzleur
 - Falmouth
Hi there folks. As I said in "what I am doing!" the engine in my 85 GTL seemed past its best, so I decided to rebuild one while still using my car, and then over a few days do an engine swap. Good plan, but there always seems to be loads of other jobs to do before getting to that stage. The engine rebuild has gone well, and is nearly ready but as can be seen the gearbox has a few leaks, so new seals required there. The oil was very metallic looking, hmm, not been replaced for a bit I reckon, but the box was working fine, so new seals and oil and it will be good to go. The gearbox mount was holding on by a thread of rubber, no wonder the exhaust was hitting the inner wing! After 33 years of oil fumes and dirt the chassis was caked in an oily gunge which had protected it, but I've taken the plunge and cleaned it up. As the 4 isn't an every day driver now, chassis protection isn't quite so important, although the inside of this section is waxoiled. I just need to touch in one two places with rust inhibiter and paint, but I like to keep that patina.
I've still got a bit more fettling to do, but hope in the next few days to make a start on reassembly. Regards Brian
