montenegro
does anyone know why there are 2 lengths of drive shafts 660mm & 700mm.
That's not the case the shafts are listed for the 354. Gbox on oscaro at both lengths and nothing to do with the old gboxIn late 73 the gearbox was changed to a type using shafts that push inside gearbox
Early cars had different shorter shafts fitting over external splines and a roll pin to locate
Yes strange, I recently had a sahaft fail and fitted a short shaft, which is easier no dropping the btm ball joint, the shaft tore itself apart within 3 kms!40mm is a lot of difference in that case if we are staying with 354 ha0 boxes
I've never measured one and only ever visually identified R4/5 mk1 from my shelf and after checking correct wheel bearing shield setup fitted without an issue
Strange?
