Briangrech
 - Malta
Thanks for your help!I did it my own way - https://www.renault4.co.uk/gordini-outerrrsusp.htm The outer rear suspension mounting has a complicated construction. You can get repair sections where you cut the old one off and weld a new one onto the chassis rails.
The rear suspension is very sensitive to accurate hole positions. Inners for height and outers for fore-aft. After messing a couple of them up I made a jig. https://www.renault4.co.uk/suspension-jig.htm
Great job well played!Thanks for your help!
Thanks a lot have figured it out but no harm in having the design, will send you my email.Thanks a lotThat is rear side of side crosmember?
I have some ACAD drawings for it.
Can send it to you earliest tomorrow during morning.
Give me email where to send it.
So normally rustproofing doesnt work satisfactorily ? I would like to know more about thatI did it my own way - https://www.renault4.co.uk/gordini-outerrrsusp.htm The outer rear suspension mounting has a complicated construction. You can get repair sections where you cut the old one off and weld a new one onto the chassis rails.
When the rear corners are affected with rust then the front corners are as well. You need to replace it with repair sections and use a rear suspension jig for keeping the dimensions.So normally rustproofing doesnt work satisfactorily ? I would like to know more about that
