Grenuj
- Ulcinj
When I installing mech. temp gauges, I should first will need to drill or cut a hole in firewall to route the capillary tubing..OK.
I have determined where the gauge will be mounted on dash..
Where to mount the sender? Existing plug on the water pump? I tried to undo this using a 8mm Allen key... unsuccessfully..
Plug on top of the pump, what is the purpose?
I'm about out of ideas....please help! And thank you in advance for any suggestions or information!
