This 4L don't have starting handle, I will turn the engine without the plugs!! This tip probably save some future problems.Some Renaults have a starting handle. I would turn the engine using this to begin, and later use the starter motor to turn the engine WITH THE PLUGS REMOVED so it won't start. do this until the oil pressure warning light goes out, indicating that the oil pressure is high enough to cover all the bearings and rocker valves.
It's done!The pipe between the tank and the pump might need a clean, too.
