Briangrech
- Malta
Hi i gave the media blaster the rear axle as a solid piece and it came in two pieces,. Any tips please on how this should be mounted as it was?
Hi i sent you a message.thanksHi I am not to good on posting pics on a site but if you can give a email address I have just dropped the axel out of my 4GTL
and I will mail you detailed pictures before I start work on it if that is of help I am going to replace the boxes each end
Gerald
Thanks i think i have understood how it should be assembled. Never worked with torsion bars and i shy away from them.I am used with Fords and simpler/moder ways of suspension, this is all new to me.It's not a rear axle as such, it's a truly independent suspension. It's better and easier at this stage to remove each torsion bar from the suspension arms (don't mix sides!), fit the arms on the chassis then follow the Haynes or Renault manual instructions for refitting the bars. It will be way easier to reset ride height when the car is completed.
