How to fit spot lights to the front of a R4- With Photos- Solved
Sprackers
Tunbridge Wells England
Has anywone or oes anywone know the best way to fix two rally spotlights to the front of a renault 4?
Cheers
Sprackers
Ive been working on something similar. Ive made two bits of steel wich sit behind the grill on the lip and then screw the lights through the grillinto the lights.
Between the bits of steel and the grill, on thi inside I made two bits of wood theat fill the gap between the steel and the back of the grill so I dont pull the grill back and snap it.
Will send photos
There was no option but I had to affix the big spotlights to the front of the grill. I did initiallly put them on the bumper but I couldnt open the bonnet.
Problem was the grill isnt designed or strong enough to hold two big heavy spotlights.
This was my solution
Photo 1:
This is the view of the back side of the grill from the inside of the car.
Notice around the grill is a lip of metal. this is the key to holding the sportlights.
Photo 2.
I made two Shims of wood that fit inside the lip and are the thickness the same as the lip of metal top an bottom. these are just slotted in
Photo 3.
An inch wide bit of steel that is long enough to sit on the lip of the metal surround and over the wooden shims.
Now from the front of the grill mark where you want the hole of the nut to go through that will hold the spotlights.
My hole was the very bottom hole in the grill.
I then remove both shim and metal plate and drilled a hole in both
Then put them back and put the spotlight holding bolt throught the shim and the metal plate and put a nut on the back.
Photo 4.
Nut in place Spotlights secure and most importantly of all, not putting any pressure on the grill.
Happy rallying
Sprackers
ps. I have lowered the price of my Renault 5 Campus for sale to £595
Only a month to go before Chrisitne an I set off for Austria and She has her snow tyres and rally lights in place. I think I ve thought of everything but if anyone has anything I might have forgotten about driving in snow an ice an cold weather please let me know.
One silly question!
Did you check cooling fluid freezing point?
If it is somewhere between -10°C and 0°C I would change it for more harder temperatures.
-25°C seem reasonable for route you are planing to do!
There are no silly questions here......
I didnt thnk of that . Brilliant. I never new there was a harder lowere temperatire anti freeze. I was thining Vodka:laughing:
pure antifreeze should be -40°C to -45°C and you dilute it with distilled water to needed/wanted temp.
-40°C can be bad for old cars. It can effect radiator and water pump to start leaking, so -25°C is something you should looking for
P.S. I like your licence plate. :D
My way - every ALU holder I screwed with 4 screws.
Did mine the same way as Sprackers (with slight modification) It works well
