The tab worked on that one then ?I bought one of these for a GTL last year: https://www.ebay.co.uk/itm/394338639478 The thing to be careful about is that is has the tab at the bottom for the mounting clamp.
That one has the tab. Just the bit of plastic sticking out a bit at the bottom for the clamp to clamp on. A lot of them don't have it.The tab worked on that one then ?
Thanks so much. Did you manage to source an air filter here in the UK?That one has the tab. Just the bit of plastic sticking out a bit at the bottom for the clamp to clamp on. A lot of them don't have it.
Thanks. I heard the sizes vary.Battery: Bosch S3 048
For the air filter, I recommend measuring your existing one, as there are several different sizes. Last year I fitted 27.701.00 UFI Air Filter Replaces 1498432,5000009,5006949,855510100
Thanks this one too but 91.. I'll give it a goOurs is a 1990 GTL built in Slovenia, so has some differences to GTLs built elsewhere.
