Cyprusnoddycar
- Cyprus EU
I was fitting my new drive shafts today, and everything was going well until I noticed that the clips on the outer drive shaft CV joint rubber boots are touching the lower steering arms ? So I guess the new reproduction Upper/Lower steering joint tapers are incorrect and going in too far ? I flattened off the clip as much as possible, but it still fouls the arm, when turning the steering. The only way I can see around it is to make 'Dent' in the top of the lower arms with a large 'Ball peen' hammer to make the clearance ? Has anybody else had this problem before ? Thanks Kevin
