MIRABELLE
- France Orne
I know this maybe off the usual type on here but here's hoping. I have recently aquired a 1956 4CV which has been well restored. It is fitted with a Solex 22 ICBT and has an automatic choke from the exhaust heat. This seems to work OK now I freed of the spindle that the spring turns. I have had the carb appart and cleaned it. I have fitted a new little rubber diaphragm. Although I don’t know what this does.The problem I have is I cant get it to idle smoothly after it gets to working temp. The volume control screw ((W) on drawing) has no effect. The spec says screw home then out 3 turns. But this screw does nothing at whatever setting. It does not hunt so not rich it seems to be running weak. I suspect it may be a problem with the auto choke but not sure. I am at a loss where to look next, so any ideas please.
