I've already posted about a possible air leak but my running issue isn't that. So my car starts but dies after a short time, I can only assume that it's when the float bowl empties. I've thoroughly cleaned the carb as in taken it apart and cleaned the jets etc, the pump is working, the filter is okay, I took the pipe off the inlet and fuel pumps through on starting. The needle valve is also 'roughly' at the correct measurement and I've tried starting without the fuel cap on just in case of negative pressure but still the same issue. The car will start okay but will stop after a short time.
I have no idea what to try next, so frustrating. Can anyone help please?
