LittleDuckAlex
- Sheffield
Hello! Long time forum lurker here. Finally created an account because I could use some advice. Apologies for all the text but I wanted to get down everything I thought was relevant.
The engine/carb:
845cc (800-05) engine with a Zenith 28 IF (V05075) carb.
The main issue:
The idle is too high, inconsistent between startups, and the revs don’t come back down fully after using the throttle for the first time.
Additional known issues:
There are a couple of things I’ve noticed that will need addressing. First, the 1.3mm jet from the oil fume rebreathing system appears to be missing, unless it’s in the elbow on the manifold, but I don’t believe it is. For now I have blocked the hose going from the manifold. Secondly, the idle mixture screw looks to broken on the end as well as being very worn higher up. Also, the brass fitting with the hole for the mixture screw is actually loose, so likely not air tight. I will replace the screw and attempt to epoxy the fitting in place so it’s air tight and can’t fall out like it has on me whilst cleaning. At the time (back in November) I wasn’t thinking properly about it and put it back in place without considering the consequences of it being loose. This isn’t causing the main issue though as I tried running with the screw out, using my finger to cover the hole, and the main issue persisted.
In the most recent run I observed the following:
980rpm fully covering the idle mixture hole, with the idle speed screw backed out all the way to the point it does nothing. Using my finger to adjust mixture I could increase the revs up to 1050rpm. Increasing the revs and letting off, it dropped down to a varying 1250-1300rpm. They don’t seem to come down until the engine is left to cool before starting again. The idle is supposed to be 700rpm for my setup.
The choke is definitely fully open, I’m not even using the cable as that just broke so I’m doing it by hand. The initial opening for the throttle is correctly set at 0.85mm. The timing is set to 6°. The carb has been removed, cleaned, and put back together with new gaskets. The oil rebreather hoses have been replaced (the 1.3mm jet was not in the old hoses). I have a new needle valve but I’ve got the old one fitted. The kit I bought didn’t come with two different size washers as some do, and I compared the height of the old one to the new one and they’re 0.5mm different, the same difference between my carb and later ones (0.84mm vs 0.89mm height from the carb body). The tolerance is 0.1mm so I decided to keep the old one in.
My thinking has been that it’s a vacuum leak, but I used a smoke leak detector and couldn’t see anywhere. I could have missed something though as the smoke comes out of the air filter above the float chamber, making it hard to see a small leak. I attempted to cover it up the best I could but even then it still came through a bit and I couldn’t see smoke coming from anywhere else.
Despite not being able to see a leak anywhere, I’m still not entirely convinced it isn’t one or multiple small ones. The carb body was pretty badly warped to the point where the base surface varied by 2mm. I sanded it down so it was flat but potentially could have done a better job. The surface where the two halves joined was also not so good and I sanded that a bit too. I just didn’t want to overdo it. It does concern me slightly with how much warping there’s been. The plug that covers the manufacturing hole above the idle mixture screw had fallen out at some point in the past and had been replaced with rubber. This had perished and fell out when I begun cleaning the carb. I’ve since sealed it with a brass disc and epoxy. Is the carb potentially a lost cause? I’m hoping not and that I can repair it sufficiently for use.
So what could be causing the issue?
Could it maybe be the needle valve? Is it worth swapping the old one out for the new, despite it then being out of tolerance?
Could it be something other than a vacuum leak or leaky needle valve?
I’m obviously not going to be able to tune things without a new mixture screw, but I’d like to know what’s causing the idle to vary and not come back down before I start taking the carb apart again and ordering more parts.
I’d appreciate any suggestions.
Alex
The engine/carb:
The main issue:
Alex
