mojobaby
Last week I took my car (GTL),Genevieve, for my 2 year roadworthy and of course I failed, which is usually the case.
Surprisingly enough, my emissions were only 3.50%, and thats probably because I turned out the mixture screw on the carb only one revolution in stead of my usual 2 and a half.
The left front tie rod has a yoke at the end which has something called a swivel bearing (according to Haynes) and the rubber inside is worn and has to be replaced.
Also the back brake flexible pipes have to be replaced as the ends have rusted.
My biggest concern is that there is play in the back left wheel. My first thought was that I would have to replace the wheel bearings, both inner and outer. If the bearing are worn, would they not be making a noise? I know that there is a castellated nut that is usually tightened by hand to take up any endplay. Perhaps this is the problem and solution
Any thoughts and advice please
