Front O/S torsion bar adjustment. Update !
Cyprusnoddycar
Cyprus EU
Greetings from Cyprus,
My R4 is running well, although it handles really badly due to the front O/S (driver side) torsion bar needing adjustment. I did the correct measurements and it is 3 cm lower than the N/S ! So I have ordered the correct adjusting tool from De Marco in Italy. Although I am not sure if I have the fixed non adjustable type of torsion bar ? It's not very clear in the Haynes manual. Thanks Kevin
Since the production from 1961 every front and rear torsion bar (left and or right) is adjustable, there are NO fixed non adjustable versions.
On the first generations of 4L, the torsion bars are adjusted using a lever attached to the rear end of the bar, which has 4 or 5 possible tightening positions on the chassis. The end of the bars (where the lever or the axle is attached) is hexagonal. This adjustment system is not very precise, but still adjustable.
From the end of 1968 (1969 models) and until 1978, the ends of the bars are no longer hexagonal but notched. The height under the body is achieved by modifying the notching of the bars in the axle and the anchoring lever and the "fine" adjustment is achieved using a cam pressing more or less on the anchoring lever of the torsion bar.
Finally, models since October 1978 have a fixed anchor bearing at the chassis level. The adjustment is therefore made only from the notching at the end of the bars, this thanks to an improvement in the production and control of the bar calibration. This system is optimal (for an R4 of course), a shift of one notch modifies the height under the hull by a fixed value.
Okay many thanks for all this information, so it looks like I have the post October 1978 set-up with the fixed anchor on the chassis. So I will have to reposition the torsion bar after marking the original spline position. I guess moving 1 spline must make the car 1cm higher ? I have been working on cars for 55 years, although never done this job before. I have also found a Youtube video as well in French, to guide me. Thanks again Kevin
Some years ago I had posted a tutorial here: https://www.renault4.co.uk/forum/threads/how-to-set-front-ride-heights.5693/#post-33719
It's a more involved job than you think. Besides the anchor lever spanner, you will need a long (~1m) pipe for leverage, and space uder the car for this, so you have to work on a lift.
Before making any measurements take the front ant roll bar out completely and fit it again only after you have completed the adjustment.
Thanks for the info Angelos, the French guy in the Youtube video used a shorter lever about 33 cm long with a hydraulic jack which worked well to release the torque on the torsion bar, and reload it again after adjustment. I printed off the instructions from your 2012 post to follow.
Update: I am having big problems adjusting the O/S (Driver) torsion bar to the correct ride height, and think either the torsion bar is weak, or someone else has fixed the bar in the wrong position in the front end ? I spent 2 hours trying to remove torsion bar from the splines yesterday, but it just won't budge And I can see someone else has been bashing around the flange before trying to remove it. I even tried heating it up with a blow torch to try and remove it but all to no avail. So I have decided to dismantle and remove the lower front suspension wishbone today complete with the torsion bar. It's great fun, although not so easy when you are 73 ! But then I hate having nothing to do.
Fwiw Try as I might I couldn't budge my rear torsion bars with 'normal' heat had to enlist a friend who's got a portable ish oxy acetalyne set & even then it took some doing. Not always an option I know but it was the only way in the end I could get it to budge. Good luck with it keep us posted the front seems a lot more involved
Thanks ! I have never had splines stuck like this in 55 years working on cars. It's like they are welded in ! Bloody Renault's !
Once you disassemble the front suspension and leave the lower wishbone hanging, unbolt the rear anchor bracket. The torsion bar should simply pull free from the wishbone.
With regard to the rear torsion bars, once the shock absorber has been removed, and the
swinging arm supported with a jack, and the bar sprayed with penetrating oil, it should come loose with the help of a suitable bar and lump hammer.
I made up this adjustable bar to take the place of the rear shock absorber, and to give fine adjustment. With regard to the front torsion bar adjustment you need to count the splines. 22 at one end and 21 at the other, and turn the bar CW or ACW to get the desired height. With both operations of course the front anti roll bar must be removed, and the back one if fitted also. Good luck, Bry.
Thanks for the useful info !
Well, I have removed the front O/S leg complete with the torsion bar ! I then held the torsion bar in the vice so I could give it a good old wack with a large brass drift and a club hammer to prevent damage, after soaking it in WD40 overnight. And it still took some effort to release it from the splines. I would have never been able to remove it on the car for sure, with the splines corroded in solid. I had to use a small file to clean them properly. The big white mark is the position my bar was in, although I found a small triangular pointer stamped in the flange as well (the small white dot). Will use Angelos/Cornish4 instructions to raise the O/S (Driver) side.
Thought I would do a trial run setting up the splines on the front suspension before I reassemble it. I have moved the original setting by X3 splines ANTI clockwise to the yellow mark (for the O/S RHD driver side) to raise the car. And have left the anchor bracket in its original position. I have counted the splines at 21 and 22 the other end. I can always adjust the ride hight again if incorrect, at least I can remove the spline end now if necessary ! This job is a learning curve for sure.
It's not easy to explain how to do this, but you do have to move both ends the same number of splines. Remember 22 at one end and 21 the other, so you have fine adjustment.
I would fit the bottom arm back on, and when you think you have correct height use a small scissor jack to raise it up for reassembly. Are you doing both sides? If so strip both sides and adjust each side the same amount.
It is trial and error, but you will get there.
Best of luck, Bry.
Best of luck, Bry.
Cheers Bry, I am reassembling tomorrow ! the other side is fine. I was surprised how much the anchor arm increased direction by just moving one spline. (about 2 cm at the support holes). As they say patience is a virtue ! Will let you know how I get on. Best Regards Kev
It's easier if you install the bar as per the Haynes instructions (supplement, on the fixed mounting chapter), that is, with the lower arm on the car and the damper fully extended, position the bar so that the anchor lever edge is 10mm from the floor aperture edge. Tension the bar, roll the car on the ground and measure ride height. You will have a good starting point for final adjustment,which may only need one or two atattempts.
Don't forget to grease both splined ends with graphite greaae
I tried fitting the torsion bar a couple of times today, with what I thought were the correct settings, but the X2 anchor fixing holes would not line up ? so I have something wrong ! I think moving X3 splines on the wishbone is far to much, so will return it to its original factory position and adjust using the anchor end tomorrow using the Haynes manual as you have said. Your instructions from 2012 are good. Thanks
Altering the torsion bar position by one tooth at one end only will affect ride height by some 60mm - definitely not fine tuning! Imagine both the wishbone and the anchor lever as stationary and the bar being rotated. The anchor lever will end up at a slightly different position because tooth number is unequal berween the two ends of the bar.
Trying to line up both holes on the later type of fixing is tricky if not dangerous if you don't have a lever of at least 1m or an arrangement like Renault's tensioning tool.
I am still struggling to find the correct ride height, because it's still far to low. Yet when I increase the spline by one to raise the car, the mounting holes will not line up ? I tried many different combinations all to no avail. And I was losing my cool, so I shut my garage door and came in for a cup of tea. Will give it another go another day. :( The early type of adjustment looked so easy, so why did Renault change it to this stupid design ? It's a frustrating job !
Kevin, can I suggest you strip the other side, leaving the bottom wishbone and torsion bar in situ and undisturbed. Now you can try the offending bar in various settings until the two wishbones look to be in the same position/angle.
Remember, you do have fine adjustment if you move each end of the bar by one spline at a time. Who knows why the French conceived this design, it's anybodies guess.
Failing this Kev, how about a nice bottle of vino on the terrace, feet up, and just say
_ _ _ _ it !! Good luck my friend, I drink to your good health, hic :drunk:
