craig smith
- northamptonshire
I own a Renault scenic 2.0 IDE Fiji and most of the time it's like the battery is dead.engin will crank once as if battery is low then gradually speed up.then,sometimes it will start and others,it just drains the battery.in the cockpit,rev counter,speedo and petrol gauge try to go backwards when ignition is turned on but this stops after around 5 seconds and a buzzing noise can be heard from behind the instrument panel which stops at the same time as the dash clocks going backwards.the digital clock also resets itself which leads me to think it's some sort of electrical problem,however now,on startup,I turn key,I get the coil light which goes out but when engine is started coil light,petrol light and service light com on then go out and engine is lumpy.a couple of blips of the throttle sorts out the lumpyness.any ideas as to what this can be would be very much appreciated.thanx
